Z0 has moved to +150 above the bed.
ive been trying to reset my z height after running G32 S2 bed leveling and something went wrong - my printer now think z0 is about 150mm above the bed.
how can i reset the height to where i want it ?
Recv:16:51:00.217: X:0.00 Y:0.00 Z:0.000 E:0.0000
but its nearly at the top of the Z range... how do i move Z to go below 0 ?
apart from winding the steppers round manually i cant get it to go down.
disables target position check so negative Z positions are possible.
Did you already check z probe height in eeprom as I told?
Z-probe height is 2.0
i tried G1 S1 - get no response on the console.
and doesnt allow me to go negative. am i missing something ?
z-probe y offset is set to 32
when i try G32 S2 i get...
21:54:39.448 : Error:Activating z-probe would lead to forbidden xy position: -65.000000, -32.01
Or how else do i get around this?
What are other people's probe offsets set to ?
Does homing z go until bed level or stop early? If it goes to bed level and back up it can also be
when it is 150 it will go up after z end stop by that distance and call it z=0.
G1 S1
just allows negative z, you still need to send moves to that e.g.
G1 Z-50 F1200
