I cannot get extruder temp above 180, why?
Hi there, printed my first test print... not bad (25 cm cube). Having problems with PLA adhering to bed (who doesn't), trying different things at the moment, would like to raise temp of my extruder to 185 or 190 to see if that helps. Unfortunately, RH interface locks at 180. It's set up as 190 in Gcode, and in my Printer Settings, I also even checked Slicer Configuration; all set to 190.
Anyone have an idea what's going on?
Also, using PLA because I've read it "adheres" better to bed and you don't need to heat bed. Well, it won't stick at all when it's not heated, sticks "sometimes" when I put the bed all the way up to 80c. is that normal?
thanks for any help!
