Z-homing stops working after turning FEATURE_Z_PROBE on
I am trying to set up a sparkcube.
After all the basics (all axis move in the right directions, homing works),
next I wanted to progress to auto-leveling.
However, as soon as I set "FEATURE_Z_PROBE 1", homing doesn't work anymore.
The z_min_endstop doesn't even change states anymore when the probe is triggered.
When I try to autolevel, the z-axis moves in the wrong direction and then stops after about 30mm.
I'm sure I am overlooking something very basic here, but I just can't see it. Please help!!!
Hardware is a RADDS 1.5, the config was created using the web tool (V1.04):
along with Repetier-Firmware. If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 1.0.4dev
as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#define HOST_RESCUE 0
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
#define FAN_THERMO_THERMISTOR_TYPE 14
#undef Y_MIN_PIN
#define Y_MIN_PIN -1
#undef X_MAX_PIN
#define X_MAX_PIN -1
#undef Z_MAX_PIN
#define Z_MAX_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL 1
#define BLUETOOTH_BAUD 230400
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 1
#define XAXIS_STEPS_PER_MM 320
#define YAXIS_STEPS_PER_MM 320
#define ZAXIS_STEPS_PER_MM 1600
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 370
#define EXT0_INVERSE 1
#define EXT0_ENABLE_ON 0
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_MAX_ACCELERATION 100
#define EXT0_HEAT_MANAGER 1
#define EXT0_PREHEAT_TEMP 190
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN2_PIN
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_X_POS 10
#define FILAMENTCHANGE_Y_POS 10
#define JAM_METHOD 1
#define JAM_STEPS 5000
#define JAM_SLOWDOWN_STEPS 5500
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 7000
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define TEMP_GAIN 0
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define HEATED_BED_MAX_TEMP 130
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 290
#define MAX_DEFECT_TEMPERATURE 310
// ## Laser configuration ##
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
#define LASER_WARMUP_TIME 0
#define LASER_PWM_MAX 255
#define LASER_WATT 2
// ## CNC configuration ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define CNC_PWM_MAX 255
#define CNC_RPM_MAX 8000
#define CNC_SAFE_Z 150
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 2
#define ENDSTOP_Y_BACK_MOVE 2
#define ENDSTOP_Z_BACK_MOVE 1
#define ENDSTOP_X_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 2
#define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 1
#define ENDSTOP_X_BACK_ON_HOME 20
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 1
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 1
#define INVERT_Z3_DIR 1
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 235
#define Y_MAX_LENGTH 245
#define Z_MAX_LENGTH 350
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 0
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define BABYSTEP_MULTIPLICATOR 100
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define STEPPER_INACTIVE_TIME 60L
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 10
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 10
#define HOMING_ORDER HOME_ORDER_YXZ
#define ZHOME_PRE_RAISE 0
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define ENABLE_BACKLASH_COMPENSATION 1
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 1
#define DIRECTION_DELAY 0
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define PRINTLINE_CACHE_SIZE 64
#define MOVE_CACHE_LOW 10
#define EXTRUDER_SWITCH_XY_SPEED 50
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define FEATURE_TWO_ZSTEPPER 1
#define FEATURE_THREE_ZSTEPPER 1
#define Z4_STEP_PIN ORIG_E3_STEP_PIN
#define Z4_DIR_PIN ORIG_E3_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define EMERGENCY_PARSER 0
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 2
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET -45
#define Z_PROBE_Y_OFFSET -7.5
#define Z_PROBE_SPEED 4
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 2
#define Z_PROBE_DELAY 0
#define Z_PROBE_START_SCRIPT "M117 Bett ausrichten...\nM206 T3 P153 X190\nG28\nG1 X150 Y150 Z10\nM117 Fertig!"
#define Z_PROBE_FINISHED_SCRIPT "G28"
#define FEATURE_AUTOLEVEL 0
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 0
#define Z_PROBE_X2 20
#define Z_PROBE_Y2 230
#define Z_PROBE_X3 230
#define Z_PROBE_Y3 230
#define BED_LEVELING_METHOD 0
#define BED_CORRECTION_METHOD 1
#define BED_LEVELING_GRID_SIZE 3
#define BED_MOTOR_1_X -15
#define BED_MOTOR_1_Y -62
#define BED_MOTOR_2_X 104
#define BED_MOTOR_2_Y 248
#define BED_MOTOR_3_X 225
#define BED_MOTOR_3_Y -62
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 7
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 0
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define LANGUAGE_RU_ACTIVE 0
#define UI_PRINTER_NAME "Beuti Spark"
#define UI_PRINTER_COMPANY "Beuti"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 2
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_MAX_HEATED_BED_TEMP 140
#define UI_SET_MAX_EXTRUDER_TEMP 290
#define NUM_MOTOR_DRIVERS 2
#define MOTOR_DRIVER_1(var) StepperDriver<64,63,65,1,0> var(1600,2)
#define MOTOR_DRIVER_2(var) StepperDriver<51,53,49,1,0> var(1600,2)
#endif
"editMode": 2,
"processor": 1,
"baudrate": 115200,
"bluetoothSerial": 1,
"bluetoothBaudrate": 230400,
"xStepsPerMM": 320,
"yStepsPerMM": 320,
"zStepsPerMM": 1600,
"xInvert": "0",
"x2Invert": 0,
"xInvertEnable": "0",
"eepromMode": 2,
"yInvert": "1",
"y2Invert": 0,
"yInvertEnable": "0",
"zInvert": "0",
"z2Invert": "1",
"z3Invert": "1",
"z4Invert": 0,
"zInvertEnable": "0",
"extruder": [
"id": 0,
"heatManager": 1,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 14,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "1",
"invertEnable": "0",
"acceleration": 100,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 370,
"coolerPin": "ORIG_FAN2_PIN",
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 190
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 2,
"yMinEndstop": 0,
"zMinEndstop": 1,
"xMaxEndstop": 0,
"yMaxEndstop": 2,
"zMaxEndstop": 0,
"x2MinEndstop": 0,
"y2MinEndstop": 0,
"x2MaxEndstop": 0,
"y2MaxEndstop": 0,
"motherboard": 402,
"driveSystem": 1,
"xMaxSpeed": 200,
"xHomingSpeed": 40,
"xTravelAcceleration": 1000,
"xPrintAcceleration": 1000,
"yMaxSpeed": 200,
"yHomingSpeed": 40,
"yTravelAcceleration": 1000,
"yPrintAcceleration": 1000,
"zMaxSpeed": 10,
"zHomingSpeed": 10,
"zTravelAcceleration": 100,
"zPrintAcceleration": 100,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Y motor",
"step": "ORIG_Y_STEP_PIN",
"dir": "ORIG_Y_DIR_PIN",
"enable": "ORIG_Y_ENABLE_PIN"
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "1",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 60,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 235,
"yLength": 245,
"zLength": 350,
"alwaysCheckEndstops": "0",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "0",
"xHomeDir": "-1",
"yHomeDir": "1",
"zHomeDir": "-1",
"xEndstopBack": 20,
"yEndstopBack": 1,
"zEndstopBack": 0,
"deltaDiagonalRod": 445,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 150,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 24,
"stepperHighDelay": 1,
"directionDelay": 0,
"stepDoublerFrequency": 80000,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 0.3,
"moveCacheSize": 64,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "1",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "1",
"mirrorZMotor": {
"mirrorZ3": "1",
"mirrorZ3Motor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"mirrorZ4": "0",
"mirrorZ4Motor": {
"name": "Extruder 3",
"step": "ORIG_E3_STEP_PIN",
"dir": "ORIG_E3_DIR_PIN",
"dittoPrinting": "0",
"featureServos": "0",
"servo0Pin": 11,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "1",
"hasHeatedBed": "1",
"enableZProbing": "1",
"extrudeMaxLength": 160,
"homeOrder": "HOME_ORDER_YXZ",
"featureController": 7,
"uiPrinterName": "Beuti Spark",
"uiPrinterCompany": "Beuti",
"uiPagesDuration": 4000,
"uiHeadline": "",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 2,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 10,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "0",
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 140,
"uiMinEtxruderTemp": 170,
"uiMaxExtruderTemp": 290,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 130,
"bedSensorType": 14,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 1,
"bedPreheat": 55,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": -1,
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 290,
"minDefectTemp": -10,
"maxDefectTemp": 310,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN_PIN",
"featureFan2Control": "0",
"fan2Pin": "ORIG_FAN2_PIN",
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 255,
"fanThermoMinTemp": 45,
"fanThermoMaxTemp": 60,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 14,
"scalePidToMax": 0,
"zProbeBedDistance": 10,
"zProbeDisableHeaters": "0",
"zProbePullup": "1",
"zProbeOnHigh": "0",
"zProbeXOffset": -45,
"zProbeYOffset": -7.5,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 4,
"zProbeXYSpeed": 150,
"zProbeHeight": 2,
"zProbeStartScript": "M117 Bett ausrichten...\\nM206 T3 P153 X190\\nG28\\nG1 X150 Y150 Z10\\nM117 Fertig!",
"zProbeFinishedScript": "G28",
"featureAutolevel": "0",
"zProbeX1": 20,
"zProbeY1": 0,
"zProbeX2": 20,
"zProbeY2": 230,
"zProbeX3": 230,
"zProbeY3": 230,
"zProbeSwitchingDistance": 1,
"zProbeRepetitions": 1,
"zProbeMedian": "0",
"zProbeEveryPoint": "",
"sdSupport": "0",
"sdCardDetectPin": -1,
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 2,
"yEndstopBackMove": 2,
"zEndstopBackMove": 1,
"xEndstopRetestFactor": 2,
"yEndstopRetestFactor": 2,
"zEndstopRetestFactor": 1,
"xMinPin": "ORIG_X_MIN_PIN",
"yMinPin": -1,
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": -1,
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": -1,
"x2MinPin": -1,
"y2MinPin": -1,
"x2MaxPin": -1,
"y2MaxPin": -1,
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 100,
"pdmForHeater": "0",
"pdmForCooler": "0",
"psOn": -1,
"mixingExtruder": "0",
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "",
"pauseEndCommands": "",
"distortionCorrection": "0",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"featureRetraction": "1",
"autoretractEnabled": "0",
"retractionLength": 3,
"retractionLongLength": 13,
"retractionSpeed": 40,
"retractionZLift": 0,
"retractionUndoSpeed": 20,
"filamentChangeXPos": 10,
"filamentChangeYPos": 10,
"filamentChangeZAdd": 2,
"filamentChangeRehome": 1,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "1",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 5000,
"jamSlowdownSteps": 5500,
"jamSlowdownTo": 70,
"jamErrorSteps": 7000,
"jamMinSteps": 10,
"jamAction": 1,
"jamMethod": 1,
"primaryPort": 1,
"numMotorDrivers": 2,
"motorDrivers": [
"t": "Stepper",
"s": "StepperDriver<64,63,65,1,0> var(1600,2)",
"invertDirection": "1",
"stepsPerMM": 1600,
"speed": 2,
"dirPin": 63,
"stepPin": 64,
"enablePin": 65,
"endstopPin": -1,
"invertEndstop": "0",
"minEndstop": "1",
"endstopPullup": "1",
"maxDistance": 20
"t": "Stepper",
"s": "StepperDriver<51,53,49,1,0> var(1600,2)",
"stepsPerMM": 1600,
"speed": 2,
"dirPin": 53,
"stepPin": 51,
"enablePin": 49,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 999999,
"zHomeYPos": 999999,
"zHomeHeatHeight": 20,
"zHomeHeatAll": "1",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"zProbeDelay": 0,
"uiBedCoating": "1",
"langEN": "0",
"langDE": "1",
"langNL": "0",
"langPT": "0",
"langIT": "0",
"langES": "0",
"langFI": "0",
"langSE": "0",
"langFR": "0",
"langCZ": "0",
"langPL": "0",
"langTR": "0",
"langRU": "0",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"laserWarmupTime": 0,
"defaultPrinterMode": 0,
"laserPwmMax": 255,
"laserWatt": 2,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"cncPwmMax": 255,
"cncRpmMax": 8000,
"cncSafeZ": 150,
"startupGCode": "",
"jsonOutput": "0",
"bedLevelingMethod": 0,
"bedCorrectionMethod": 1,
"bedLevelingGridSize": 3,
"bedLevelingRepetitions": 5,
"bedMotor1X": -15,
"bedMotor1Y": -62,
"bedMotor2X": 104,
"bedMotor2Y": 248,
"bedMotor3X": 225,
"bedMotor3Y": -62,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": -1,
"sharedExtruderHeater": "0",
"extruderSwitchXYSpeed": 50,
"dualXAxis": "0",
"boardFanSpeed": 255,
"keepAliveInterval": 2000,
"moveXWhenHomed": "0",
"moveYWhenHomed": "0",
"moveZWhenHomed": "0",
"preheatTime": 30000,
"multiZEndstopHoming": "0",
"z2MinMaxPin": -1,
"z2MinMaxEndstop": 0,
"extruderIsZProbe": "0",
"boardFanMinSpeed": 0,
"doorPin": -1,
"doorEndstop": 1,
"zhomePreRaise": 0,
"zhomePreRaiseDistance": 10,
"dualXResolution": "0",
"x2axisStepsPerMM": 100,
"coolerPWMSpeed": 0,
"maxFanPWM": 255,
"raiseZOnToolchange": 0,
"distortionLimitTo": 2,
"automaticPowerup": 0,
"hasTMC2130": "0",
"TMC2130Sensorless": "0",
"TMC2130Steathchop": "1",
"TMC2130Interpolate256": "1",
"TMC2130PWMAmpl": 255,
"TMC2130PWMGrad": 1,
"TMC2130PWMAutoscale": "1",
"TMC2130PWMFreq": 2,
"TMC2130CSX": -1,
"TMC2130CSY": -1,
"TMC2130CSZ": -1,
"TMC2130CSE0": -1,
"TMC2130CSE1": -1,
"TMC2130CSE2": -1,
"TMC2130CSE3": -1,
"TMC2130CSE4": -1,
"TMC2130CurrentX": 1000,
"TMC2130CurrentY": 1000,
"TMC2130CurrentZ": 1000,
"TMC2130CurrentE0": 1000,
"TMC2130CurrentE1": 1000,
"TMC2130CurrentE2": 1000,
"TMC2130CurrentE3": 1000,
"TMC2130CurrentE4": 1000,
"microstepX": 16,
"microstepY": 16,
"microstepZ": 16,
"microstepE0": 16,
"microstepE1": 16,
"microstepE2": 16,
"microstepE3": 16,
"microstepE4": 16,
"parkPosX": 0,
"parkPosY": 0,
"parkPosZ": 10,
"emergencyParser": 0,
"hostRescue": "0",
"MAX31855SwCS": -1,
"MAX31855SwCLK": -1,
"tempGain": "0",
"uiAnimation": "0",
"uiPresetBedTempPLA": 60,
"uiPresetBedABS": 120,
"uiPresetExtruderPLA": 190,
"uiPresetExtruderABS": 240,
"hasMAX6675": false,
"hasMAX31855": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 1,
"version": 100.4,
"primaryPortName": "Serial",
"hasMAX31855SW": false
  • Does homing with z probe disabled work correctly?
    When z probe enabled z min will not trigger - instead z probe triggers. That is correct and because on low z you do not want to trigger before z=0 but many z probes do.
    Homing order for z probe should be one with temperature, so you can set xy position for probing. E.g. 100/100. Problem is often that probe can not be activated due to offset at xy home position. Set required temperature to 0 so it does not force you to heat for homing.
    For bed leveling you have selected a parallelogram with
    what you want is a rectangle like:
    #define Z_PROBE_Y3 0
    That should at least improve your solution a lot.
  • Yes, with z-probe disabled homing works.
    Ok, that at least explains the z_min not working.
    I will try the suggested homing order with temperature, even though probe activation is not the problem (at least from the hardware side)
    Can I see the state of z_probe somewhere in the menu for testing?
  • No you can not see it in menu. But you can enable it for debugging with host.
    M111 S70
    activates reporting changes to serial. Do not use in production as it can crash firmware when triggered too fast in a row.
  • Thank you, that helped (a bit).
    When homing x or y, I get a useful answer, for example:
    busy:processing
    X:0.00 Y:0.00 Z:0.000 E:0.0000
    wait
    When I home Z, I seem to get a crash or more correctly a watchdog reset:
    wait
    busy:processing
    busy:processing
    busy:processing
    busy:processing
    busy:processing
    busy:processing
    start
    Info:Watchdog Reset
    Detected EEPROM version:20
    Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
    So I still don't know if my Z_Probe works, but I learned that I get resets...
    please help?
  • Does z move at all?
    Does M119 correct end stops?
    I know you get a watchdog reset on z home if your stepper frequency gets too high. I saw you have 1600 steps homing with 10 mm/s so 16000 on a due. That is normally no issue and watchdog gets reset fast enough. Or does eeprom contain different values?
  • Z does not move during homing, when Z_Probe is active.
    With "FEATURE_Z_PROBE 0", Z-homing works without a problem - therefore I do not think the stepper frequency is an issue here.
    I can also move Z 'manually' using the position menu.
    M119 works:
    endstops hit: x_min:L y_max:L z_min:L Z-probe state:L
    With sensor active:
    endstops hit: x_min:L y_max:L z_min:L Z-probe state:H
    a different question: I saw some threads in the forum in german.
    Is it easier for you to converse in german? I don't mind either way...
  • I have no problems with german (native speaker) but for others to follow and be help for them we prefer english.
    You home y max and need to move to y+ direction to activate z probe. That does not work with homing order XYZ so that might be the reason you fail. You must have home order with temperature (also set to 0) and set ZHOME_Y_POS 10 at least. Maybe it is just that. Also always watch for error messages in console when testing to get extra hints.
  • I have already changed homing to xytz - you suggested this earlier.
    Z-homing currently first homes x, then y, moves to the defined x/y coordinates for z-homing and then stops or more accurately resets...
  • So main question is why the reset. Does G30 work or does it reset as well? If it works you need to track down it to the code where it happens. I have a printer doing it this way and it works and I have no idea why it gets stuck, In printer.cpp homeAxes function in this part it might reset:
    if (zaxis) {
    #if ZHOME_X_POS != IGNORE_COORDINATE || ZHOME_Y_POS != IGNORE_COORDINATE
    moveToReal(ZHOME_X_POS, ZHOME_Y_POS, IGNORE_COORDINATE, IGNORE_COORDINATE, homingFeedrate[X_AXIS]); // correct rotation!
    Commands::waitUntilEndOfAllMoves();
    SAFE_HOMING_CALL(homeZAxis()) // real z distance at that point to zero
    if (Z_HOME_DIR < 0) {
    startZ = Printer::zMin;
    } else {
    startZ = Printer::zMin + Printer::zLength - zBedOffset;
    moveToReal(IGNORE_COORDINATE, IGNORE_COORDINATE, ZHOME_HEAT_HEIGHT, IGNORE_COORDINATE, homingFeedrate[Z_AXIS]); // correct rotation!
    #if ZHOME_MIN_TEMPERATURE > 20
    #if ZHOME_HEAT_ALL
    for (int i = 0; i < NUM_EXTRUDER; i++)
    Extruder::setTemperatureForExtruder(actTemp[i], i, false, false);
    Extruder::setTemperatureForExtruder(actTemp[i], i, false, actTemp[i] > MAX_ROOM_TEMPERATURE);
    Extruder::setTemperatureForExtruder(actTemp[Extruder::current->id], Extruder::current->id, false, actTemp[Extruder::current->id] > MAX_ROOM_TEMPERATURE);
    This is form 1.0.5 version might look different if you use older one. Try adding some strategical:
    Com::printFLN(PSTR("Mark1"));HAL::delayMilliseconds(10);
    with different messages to see until where it goes. If it happens in a sub function add there as well some tests. You can also add a parameter to see a value in print message. You will see then until where it goes and where it stucks and then you can check variables involved there to see which is 0/null or where something illegal is accessed.
    That is how I tacke all crashes I can not understand.
  • Ok, maybe I am a step further:
    after setting "#define MAX_HARDWARE_ENDSTOP_Z" from true to false the reset/crash does not occur anymore.
    Instead I get this reaction when homing (all or just z):
    - x homes
    - y homes
    - moves to defined x/y position for z-homing
    - moves in positive z by the amount defined in "#define ZHOME_HEAT_HEIGHT"
    - immediately moves back to x/y/z-position of beginning (all axis at once)
    - x and y are homed, z still shows as ?.??
    here is a copy of the current CONFIGURATION.h:
    as you expect.
    #include "pins.h"
    #undef Y_MIN_PIN
    #undef X_MAX_PIN
    #undef Z_MAX_PIN
    #define BLUETOOTH_SERIAL -1
    #define TEMP_GAIN 0
    #define MAXTEMP 290
    #define DOOR_PIN -1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    // Delta settings
    #define HOMING_ORDER HOME_ORDER_XYTZ
    #define ZHOME_HEAT_ALL 0
    #define ZHOME_X_POS 100
    #define ZHOME_Y_POS 200
    #define MAX_JERK 20
    #undef PS_ON_PIN
    #define FEATURE_AUTOLEVEL 1
    #define BED_LEVELING_REPETITIONS 3
    #define SDSUPPORT 0
    #undef SDCARDDETECT
    #endif
    #define UI_AUTORETURN_TO_MENU_AFTER 60000
    #endif
  • #define ENDSTOP_Z_BACK_ON_HOME 0
    That is for z min homing! Hope this is not what you used for z max homing test.
    What was written in console on the test? That is where the information is.
    Since sequence worked I think the problem is in the z probe activation/deactivation.
    That will not work! Especially you can not move in activation when it is used in homing so you can start homing. Also what are you changing in eeprom? That is also bad - once because it wear eeprom writes and it might trigger internal updates. Also homing at the start and end of homing is bad idea (finish script). Leave the scripts empty and it will not crash any more.
  • Thank you!!
    of course it was the scripts that caused the problems!
    My whole configuration was based on someone elses who has the same printer model.
    In hindsight it would have been faster to start my own configuration from scratch...
    Homing now works perfectly.
    Now to set up the rest of the printer...
    Thanks again for pointing me in the right direction
