Configuración TimeLapse
Hola  soy nuevo en esto , he configurado  el TimeLapse com
  •  Repetier-Host does not support configuring timelapse. When you are using  Repetier-Server Pro you can add a webcam and then in the regular web gui in the webcam tab you can activate and configure the timelapse function. In global settings is also a config tab for some global settings like conversion software to generate videos or watermarks.
