Is there a way to enter distortion values manually in unrechable Z-Probing areas
Hi, at my self made cartesian printer with double extruder the BLTouch sensor has an offset of Y +28mm.
So matrix distortion measurement is limited to Y > 28. Ymin for the matrix is therefore 28.
In the area of Y=0 there are little bumps I like to be corrected also.
Do you see a chance of a workaround (including software mods) to manually define distortion correction values for the line Y=0?
Thanks!
The measurement is done in distorion.cpp in this function:
When you make for (iy = 0; iy < DISTORTION_CORRECTION_POINTS; iy++) start with iy = 1 it would maybe work, but complete y=0 row has then no set values. That is the best I can offer.
I plan to mod it in like this:
G33 L0
lists all commands to restore. So take them for y min and modify Z for replay.
