Missing Layers and wrong Z height on Slic3r 2.+
Hi I noticed as I tried to print thin layers that somehow the transfer from Repetier host and slic3r caused missing 3 layers...
I tried a lot, and the problem lies n the amf file loading.
I loaded the "composition.amf" in slic3r and all is fine
I loaded the composition.amf in RH and saved it as stl file then run slic3r with the same settings from the command line but with the stl instead of the amf file also fine
This happens also only with thin objects at the build plate ( 20x20mm cube is fine)
Problem exists not on Slic3r 1.3 versions only on 2+
Here are all the files in question
https://drive.google.com/drive/folders/1jYE3QcfuRPosL9gMU2LwzIg41kxZXu8x?usp=sharing
A easy fix would be to use stl as transfer format again ?
best
Andreas
best
Andreas
Using STL is no option - it can not contain the extra data we transfer in amf. And it would be identical as we also recreate that from our dataset, so if our rotation causes the layer difference when you need to rotate it would also be in stl.
the model has a 1.5mm thick bottom part, I'm not talking about some small height offset.
from the stl I get about 5 layers with 0.3mm layer height ( first layer is 0.35mm)
from the amf I get only 2 layers also the z height of the layers add up to way less than 1.5mm
If I open slic3r and load the stl or the amf directly I get 5 layers.
You mean Prusa Slicer? Whcih version do you see in gcode when you check gcode? Is it 2.3.0 or 2.3.1?
If you have 2.3.0 please redownload so it becomes 2.3.1.
I could not download your samples. Had another user where it was 2.3.0 with same problem, but coul dnot reproduce with 2.3.1 bundled 2.2.0.
I think now it works
Systemsteuerung\Zeit und Region -> Datums, Uhrzeit- und Zahlenformate ändern -> Weitere Einstellungen.
