Extruder stops heating, only when still hot from previous job.
everything works, but one situation - nearly always, when i stop a print and start a new one after 1-3 minutes, while the extruder is still cooling down, it won't heat up anymore.
I start the new job, the extruder is between 120 and 160, it heats up for a short while and then stops?
When i reconnect, there is the same problem.
It only goes away when i start a job while the extruder is below 100 (this number is guessed, it just works at some point)
any ideas?
thanks
i might add: repetier latest version (had the problem before), firmware - latest i think - from 0.92 web configuration tool
