Turning off all heaters
How do I disable the new function to improve safety of turning off heaters when they do not appear to respond according to some definition in the code?
I know the question will get asked: why disable the safety feature?
I want to disable the feature because the settings do not appear compatible with my printer. After a print is complete and the extruder is still warm I try to start a new print and it always fails out within 5 seconds. That is not long enough to determine if the extruder heater is functioning correctly, IMHO. I have to waste time resetting everything for it to work again.
I suspect a bug in the host or firmware, but since I don't know enough about it I just want it turned off for now. I haven't burned anything since building the machine in 2012. But, also own a toaster, oven, microwave, gas stove (!), coffee pot, and clothes iron and can operate those as well without burning the house down so I have an advantage of experience with hot tools.
Thanks for any help with this issue.
