You mean a physical object placed on bed and probe shape? You can do that with G30 command and move between positions with G0. Use start height higher than highest object part. And make sure that no other object would collide while testing - after all it is not made for this purpose.
You mean to set a coordinate system or for using z height map for something? As said you can only test from top at set xy positions. It is not possible to detect a object position by testing from sides like you do in cnc.
Both are the same with that respect. For cnc it might come in V2 but since I'm very busy do not rely on any time plans. It has no priority since we focus on fdm mainly.
