Autolevel ignores z probe
I havent printed in a while and while Marlin is in Update hell I tried repetier with my new inductive proximity sensor. Movement works works fine, endstops report correct incl the probe and I found the z level with repetier video on youtube. I use the rod routine to set the endstop height and that seemed to work fine. However the G32 s2 command and the single point G30 and the height map test all slam the probe into the bed. I can the the led on the probe trigger but it keeps moving.
I saw that there is still a "bug" disclaimer on the repetier page in the section about autolevel but I have the feeling I oversaw a detail.
All help much apreciated
Cheers
