PT100 Amplifier Board
Hello,
I have an E3D PT100 sensor cartridge that I am trying to connect to the RADDS board. But when I turn on my printer, my LCD displays: "Temp. Sensor defect." Can you help me please?
Thanlk you.
Kind Regards;
R.H
Thanlk you.
Kind Regards;
R.H
One other question please about the ensdtops.
I have a mechanical endstop V1.2. Belows whats I did in the program. My problem is that the endstops doesn't stop the axis!
I have some issues about my mechanical Endstops. I tried evrything but with no success. When I home the axes, It just doesn't stop , they heat the endstop. Any help please!
Repetier Firmware:
Repetier Host: Endstops hit: x_min:H x_max:H y_min:H y_max:H z_min: H z_max:H (Not triggered)
should all be false.
Also M119 should report them low so e.g.
should be true to show the inverse signal.
I'm wondering it moves at all when all signals are high.
