PT100 Amplifier Board
I have an E3D PT100 sensor cartridge that I am trying to connect to the RADDS board. But when I turn on my printer, my LCD displays: "Temp. Sensor defect." Can you help me please?
Thanlk you.
Kind Regards;
R.H
  • You can not connect it to the thermistor connectors! You must use the adc pin on the long side center opposite to motor drivers and select the analog pin channel as input. Just not sure if you need to 3.3v or 5v PT100 table for conversion but both would show temperatures. The wrong one is easy to see when room temperature is way off.
  • Ok. Thank you.
    One other question please  about the ensdtops.
    I have a mechanical endstop V1.2.  Belows whats I did in the program. My problem is that the endstops doesn't stop the axis!
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 3
    #define ENDSTOP_Y_BACK_MOVE 3
    #define ENDSTOP_Z_BACK_MOVE 3
    #define ENDSTOP_X_BACK_ON_HOME 10
    #define ENDSTOP_Y_BACK_ON_HOME 10
    #define ENDSTOP_Z_BACK_ON_HOME 10
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
  • Please check with M119 if they are normally low and high when you trigger. Especially which one triggers in case you used a wrong pin header on board. You data missed homing direction but with these end stops they must have home directions -1 for all. All other values seem to make sense. Inversion might need toggling when M119 states signals wrong way around.
  • Hello,
    I have some issues about my mechanical Endstops. I tried evrything but with no success. When I home the axes, It just doesn't stop , they heat the endstop. Any help please!
    Repetier Firmware:
    #define DOOR_PIN -1
    #define DOOR_INVERTING 1
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define X_ENABLE_ON 1
    #define Y_ENABLE_ON 1
    #define Z_ENABLE_ON 1
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    Repetier Host: Endstops hit: x_min:H  x_max:H   y_min:H y_max:H   z_min: H  z_max:H     (Not triggered)
  • You really have 6 physical end stops? Then
    should all be false.
    Also M119 should report them low so e.g.
    should be true to show the inverse signal.
    I'm wondering it moves at all when all signals are high.
  • Thank you very much for ur help.It works now :)
