Rotary encoder jumps >100 steps in opposite direction during Z-babystep use
While printing an object and trying to adjust the Z-babystep on a Mega/RAMPS 1.4 with the RepRapDiscount Full LCD, I am having a really hard time using the Z babystep function with the LCD rotary encoder. If I spin the dial very slowly, it mostly works but the Z babystepping is too slow to complete an adjustment within the first layer of even a medium sized object (1 click = 0.0025 mm). If I try to spin the dial faster, I can get it to slowly come up in 0.01 increments if the printer doesn't have too many moves queued up. But if there is a rapid set of movement commands being processed while I'm spinning the rotary encoder in the negative direction at a modest pace (say I've dialed down to -0.12mm and still dialing down), the Mega board suddenly interprets at the moment of rapid movement processing that I am turning the dial in the opposite direction at breakneck speed, and the Z babystep jumps from -0.12mm to +0.50 or even +1.5 or +2.0mm. One can imagine how maddening this is when trying to dial down toward the glass, and for the nozzle to instead jump way up by a mm or two.
I also experienced a firmware lockup during rapid rotary encoder dialing when a rapid set of motions were processed (say printing a small arc with retracts and rapid travel movements on either side). The LCD stop button did not reset the firmware like usual, I had to use the Mega board's reset button.
I know I can use the Z babystepping multiplicator (sic) to reduce the amount of rotary encoder spinning, however I still think it's a defect to jump hundreds of steps in any direction for a quarter turn of the encoder dial during rapid travel/extrude/retraction instructions. Perhaps a fix would be to ignore polling of the encoder when the user has enabled the dynamic encoder speed functionality during really rapid processing.
I'm using firmware 0.92.4 with this file.
