G02 and G03 code issue
Dear Experts!
My 3D printer not interpreting this code:
G03 X99.310635 Y20.941124 Z-0.125000 I-5.784536 J6.163855
or
or
G02 X89.944938 Y25.238500 Z-0.125000 I11.597644 J-10.953337
This code was generated by the inkscape laser tool.
The 3D printer does not execute any similar line.
Why?
Why?
Enable arc support (G2/G3)
enabled or you won't have these commands.
But, where to find this options?
This is it?: #define ARC_SUPPORT 1
is correct format also I normally just write G2. Problem might be negative Z value. Normally you can not move below z=0 so that would cause a illegal position and be ignored. Except if you moved up after homing and used G92 Z0 to mark that position zero. Then you can go as low as Z when sending G92.
If I delete the negative Z data then the 3D printer is work.
Thank you your advice!
