Permanente Flow Rate and Speed
Could you put the option to make permanent the variation of the flow and speed the same as it is in the layer fan?
  • Why? Slicers do not change it during print. Only bad thing I saw so far is that Prusa started setting flow to 95% on some layer heights. But that is in the start script so could easily be changed.
    I print the same Gcode in multiple printers. Different models and manufacturers.
  • Flow should be the same for all printers or some are not correctly calibrated. Anyway making server ignore M220/M221 does not set the value you want. It still gets lost on every connect where we init it with 100% anyway. So I see no gain in this change.
