Why? Slicers do not change it during print. Only bad thing I saw so far is that Prusa started setting flow to 95% on some layer heights. But that is in the start script so could easily be changed.
I print the same Gcode in multiple printers. Different models and manufacturers.
Flow should be the same for all printers or some are not correctly calibrated. Anyway making server ignore M220/M221 does not set the value you want. It still gets lost on every connect where we init it with 100% anyway. So I see no gain in this change.
