Poroblem with MKS Robin Nano
I have this problem that when I send My Gcode file from Repetier Host it does not print.
It seems to have to do with the M109 commands. The same G-code sent from SD card or Pronterface does not cause any problem..
What communications settings do I need?
host keepalive: on/off?
RTS? DTR?
RTS? DTR?
Because the same GCODE worked on another Computer with Repetier Host.
