E3D Cyclops with Repetier Configuration
Hi, I'm trying to figure out how to use the 2 in 1 out Cyclops hot end with Repetier firmware and Repetier Host. Right now I have the 'Mixing Extruder' option selected in both the firmware and the Host but when I try to print or even just move extruder motors separately, They seem to mirror/move at the same time. I want to be able to use it like 2 separate extruders with 1 nozzle. How can this be done?
One problem that is not easily solvable is that to activate the other extruder you must retract enough with the "old" extruder so the other can insert filament. So you need to decide how you handle this. You can do it in slicer by adding the proper code before and after extruder switches or you can use the select/deselect gcode commands for the extruder to add it there so it happens automatically.
