Timelapse failed because not disc space ... due to images not deleted after successful rendering
Hello,
after only 20-30 recordings on my raspberry all following timelapse recordings are failing.
The reason is that disc space is very low. This is because the images from the timelapse recrodings are not deleted after successful rendering. Required disc space for about 20-30 recordings is about 2GB based on my settings.
I really do not need to single images after successful rendering. Is there any possiblity to automatically delete the images after the timelapse have been rendered successful? Please provide solution for this. Thanks
Br
Christian
A function to delete the images is noted for future versions. I think even as option to do this always might be nice here on own risk. Once deleted it is of course not possible to rerender with different parameter.
