Turning off all heaters
How do I disable the new function to improve safety of turning off heaters when they do not appear to respond according to some definition in the code?
I know the question will get asked: why disable the safety feature?
I want to disable the feature because the settings do not appear compatible with my printer. After a print is complete and the extruder is still warm I try to start a new print and it always fails out within 5 seconds. That is not long enough to determine if the extruder heater is functioning correctly, IMHO. I have to waste time resetting everything for it to work again.
I suspect a bug in the host or firmware, but since I don't know enough about it I just want it turned off for now. I haven't burned anything since building the machine in 2012. But, also own a toaster, oven, microwave, gas stove (!), coffee pot, and clothes iron and can operate those as well without burning the house down so I have an advantage of experience with hot tools.
Thanks for any help with this issue.
  • More information about the issue in the figure. I really think it is a setting or coding issue.image
  • Hello? Anyone here?
  • I have recently changed a thing in decouple testing, so it could be removed. Anyway, dsiabling is not possible but you can set values that would never trigger
    #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 300
    /** Time in ms between a heater action and test of success. Must be more then time between turning heater on and first temp. rise! */
    #define EXT0_DECOUPLE_TEST_PERIOD 1800000
  • I made the adjustment and it seems to have corrected the issue. Thank you for taking the time to help.
