dual extruder off center
Hi, I'm having issues with the centering the x of the print for my dual extruder setup. It even goes off the bed sometimes because it is only 150mm^2. the x endstop is set as a max limit because it is to the right of the bed. I have the right of the 2 extruders set to extruder 0 and the left set to extruder 1. The offset on extruder 1 is x=-18. When it is at 0,0 extruder 0 should be at the front left corner of the bed. The prints are too close to the left side of the bed. Why is this happening?
Firmware reduces print area by the distance between the 2 extruders so you can switch between extruders everywhere. You will see that homing x max with extruder 0 you get a 18mm gap to the end stop while homing with extruder 1 will be next to end stop. This is just so you can switch extruders directly after homing without crashing into the end stop.
https://imgur.com/N7Bd8SY
shows that the left hand extruder should be ext0 and the righthand should be ext1.It also should 0.0 being mid point between to 2 extruders.
Try with setting
extruder0 x offset = -9
extruder1 x offset= 9
