Vertical Text in object bad definition
my name is Carles and I'm new for 3 weeks starting printing. I'm working with curaengine and there is a trouble when print text in a wall, by default makes little lines and deform text. If I change object  position theres isn't problem but I think this is not the solution.
I show image, thanks
  • Does host show that it is manifold? Non manifold object often create strange results like this. Faces are only allowed to define the outer boundary. Internal faces in model are not allowed and produce often error.
    Also better use PrusaSlicer if you are starting. It gives the best results from the integrated slicers.
  • You have reason. Is not mainfold and when repaired produce error.
    Thanks a lot.
