Vertical Text in object bad definition
my name is Carles and I'm new for 3 weeks starting printing. I'm working with curaengine and there is a trouble when print text in a wall, by default makes little lines and deform text. If I change object position theres isn't problem but I think this is not the solution.
I show image, thanks
Also better use PrusaSlicer if you are starting. It gives the best results from the integrated slicers.
