layers not aligned. I make a small rectangle and the sides are at 45 degrees.
Dear Sir:
Printer worked fine yesterday and I was making those Montana Masks for friends. Today when I print the layers are not aligned. I tried printing a rectangle (60mm length, 20mm width, and 20 mm height) and the ends are at 45 degrees. The ends should be 90 degrees. You can see the print head is moving one layer at a time to the left along the length of the rectangle.. The belts are tight. This has to be a setting someplace. I am using Repitier host is V2.1.6. Printer is a TronXY 3sx with Marlin v2.05 I think. Any ideas? Oh, the board is a Melzi V2.05. Also, the ends are too well printed to be a random print problem. I am using Slice3r which worked great yesterday. I also tried Cura and that did not work either. Could be be a virus? Never heard of such a thing, but who knows.
Thanks for all the help. Hope you all are well and stay well. Richard Brown
How does it move when you move manually 50mm left/right/up/down ? Is one move longer and one 45°
https://www.dropbox.com/sh/i5a4zwky6ev2jz5/AADFRSYR1FMcXLDJejdJ2XVBa?dl=0
