Cant get distortion correction to work.
I can do bed leveling and that works fine but when I go to do distortion correction it goes down to 10mm then stops and gives an error of “cannot activate z-probe would cause unreachable xy coordinate of 5.0000345, 5.000. “. Or something like that. I have the same probing points for distortion correction as I do for bed leveling.
I will try starting at center of bed before probing and see if that helps.
