Dual Z steppers and dual extruder
My machine is a home built cartesian using AtMega 2560 and Ramps1.4 board and dual extruders into a Y/ E3D hotend. Was using Marlin until I upgraded to dual Z steppers and a BLTouch (sadly my second extruder no longer works). Can Repetier firmware be setup to use a stepper expander board with the Ramps 1.4. If so how does one go about configuring the pins for the expander board?
now these variables are undefined, so in manual additions in config tool you add
#undef EXT2_STEP_PIN
#undef EXT2_DIR_PIN
#undef EXT2_ENABLE_PIN
with 10-12 replaced by correct pin number. That's all required.
