UART on TMC 2209 support?
Do Repetier has support for TMC 2209 UART? Because i want to use sensorless homeing.
  • Only V2 firmware supports that chip, but problem is normally that you do not have enough hardware UART ports available for all chips so using SPI version TMC2130 would be the better choice.
