Not for a while as it uses LPC1768 processor. Once V2 is more advanced I will see if we can extend to other processor types. But I can not say when and if it will work. Also depends on dependent libraries supporting the processor type.
If you are a programmer, you can write the HAL if you like. Would be glad if someone does it. But then please for V2 version. I think with PlatformIO it should get easier to add new hardware. But are there Arduino Boards using this processor? Otherwise I'd have to replace all Arduino functions - also that might be good in the long run.
in platformio.ini so there seems to be a support available for that processor with arduino framework, which makes it much easier of course. The Due is also a Cortex-M3 so I guess the differences in programming are marginal. I wonder what the difference to LP1769 is as that is what smoothieboard uses and I own that board at least. Don't have a re-arm.
Anyhow, also hal will not be identical to marlin it might help finding out how some problems need to be solved. But I need to investigate more - don't know the marlin sources good enough at the moment.
At some point yes. You can of course speed up the process by providing a hal for it from your side. Just spend 2 weeks optimizing HAL for STM32F4 used by RUMBA32 now working well. Next will be AVR then I come to smoothieboards which use the LPC I think.
in marlins case not so much as that person is to much a control freak
I'm not a programmer, but could a HAL from Marlin firmware be of any use?
marlin still come up with major boo-boo faults and their issue list contains far more errors that there should be
and i just maintain the issue list, ie format titles and close issues if stale or solved
its so frustrating that i consider to switch if i could
i remember something about smoothieware on the re-arm so i think you are correct
