MQTT Support
MQTT support would be very great.
you would have all readings centrally under FHEM in view and could switch further events with status "finisch". e.g. switch off a Sonow POW (tasmato) and thus switch off the printer.
  • MQTT is on list for future interface options. But first other more important features will come.
  • What is the current status of MQTT support?
    Viele Grüße
    Florian
  • Won't start this year due to lower priority over other functions.
  • If would like to get only information  from reptierserver you can use this software. Docker is also supported.
    That is awesome, I tried it but it won't work on my raspberry pi´s. Both stop at the same spot. Running it with python 3.7 and paho-mqtt installed.
    Every time I try to run the script it results in:
      File "repeqtt.py", line 94, in <module>
        queryRepetier()
      File "repeqtt.py", line 67, in queryRepetier
        serverKey = srvdata['apikey']
    KeyError: 'apikey'
    I already tried to use add another user with all rights and easy non special characters password.
    API should be working, since I use it in ioBroker already, that reads the data.
    I did not find any information how to maybe enable "REST API" if that is a different thing.
    Any ideas?
    Or maybe any idea how I could change the script to not query the API via User + PW but instead directly using the according API Key?
  • I have a running Home automation with OpenHab and using mosquitto to communicate between the Raspberrys and devices, i.e. to get energy consumption from smart sockets.
    So I only want to send an "event" from the Repetier-Server (when print starts) via extcommands.xml to my existing mqqt broker, what package(s) have I to install?
    Any hints? Thx!
