Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
ok my research on this tells me it comes from windows... umm great thats about as helpful as telling me someones is from China so i should be easily able to locate them! There are about 500 variables involved there im just trying to find a way to limit those to the point i can figure out whats going on.
The error seems random and doesnt always end the print i just cant figure out what the cause is.
So really anyone know what the common causes are here ?
1. USB Cable bad
2. Comm port Driver
3. Software trying to access that com port
etc etc ?
1. USB Cable bad
2. Comm port Driver
etc etc ?
http://localhost:3344
In that case do not use serial connector but Repetier-Server connector in host to print using the server (preferred solution).
