G28 only Homes Z axis
G28 only homes the z axis, doesn't even try for x and y. It is set to do x, y, then z per my firmware config. None of the endstops are tripped, and I have verified proper functionality with M119 to ensure they're High and Low as expected. It's almost like both the x and y axis are triggered by default, but they both come back with low on an M119... any thoughts as to what might be the issue here?
Printer:
Cartesian (DaVinci 1.0)
Repetier 1.0.3
Azteeg x3 pro board
E.g. if you have homing to min endstop direction = -1 and only a max endstop it will not home. Otherwise if M119 shows low before homing it should move towards the homing direction.
