Windows 10 pro latest Reptier server version cant send commands to the server.
I have this printer:
<?xml version="1.0" encoding="UTF-8"?>
<printer>
	<general>
		<name>test</name>
		<slug>test</slug>
		<model/>
		<firmwareName>Marlin</firmwareName>
		<printerVariant>delta</printerVariant>
		<active>true</active>
		<numFans>1</numFans>
		<tempUpdateEvery>1</tempUpdateEvery>
		<pauseHandling>0</pauseHandling>
		<pauseSeconds>120</pauseSeconds>
		<doorHandling>1</doorHandling>
		<sdcard>false</sdcard>
		<softwarePower>false</softwarePower>
		<defaultVolumetric>false</defaultVolumetric>
		<logHistory>true</logHistory>
		<useOwnModelRepository>true</useOwnModelRepository>
		<useModelFromSlug/>
	</general>
	<connection>
		<connectionMethod>2</connectionMethod>
		<pipe>
			<file/>
		</pipe>
		<ip>
			<port>8888</port>
			<address>192.168.0.10</address>
		</ip>
		<serial>
			<baudrate>0</baudrate>
			<rts>0</rts>
			<dtr>0</dtr>
			<device>VirtualDelta</device>
			<pingPong>false</pingPong>
			<visibleWithoutRunning>false</visibleWithoutRunning>
			<malyanHack>false</malyanHack>
			<inputBufferSize>127</inputBufferSize>
			<communicationTimeout>30</communicationTimeout>
		</serial>
		<lcdTimeMode>4</lcdTimeMode>
		<resetScript/>
	</connection>
	<movement>
		<xMin>-100</xMin>
		<xMax>100</xMax>
		<xHome>0</xHome>
		<yMin>-100</yMin>
		<yMax>100</yMax>
		<yHome>0</yHome>
		<zMin>0</zMin>
		<zMax>100</zMax>
		<zHome>0</zHome>
		<xyJerk>20</xyJerk>
		<zJerk>0.30000000000000004</zJerk>
		<timeMultiplier>1</timeMultiplier>
		<movebuffer>127</movebuffer>
		<xySpeed max="200">100</xySpeed>
		<zSpeed max="2">2</zSpeed>
		<defaultAcceleration>10000</defaultAcceleration>
		<defaultTravelAcceleration>10000</defaultTravelAcceleration>
		<defaultRetractAcceleration>4000</defaultRetractAcceleration>
		<xyPrintAcceleration>1500</xyPrintAcceleration>
		<xyTravelAcceleration>2500</xyTravelAcceleration>
		<zPrintAcceleration>100</zPrintAcceleration>
		<zTravelAcceleration>100</zTravelAcceleration>
		<endstops all="true" x="true" y="true" z="true"/>
		<invert x="false" y="false" z="false"/>
		<G10Speed>50</G10Speed>
		<G10Distance>3</G10Distance>
		<G10LongDistance>50</G10LongDistance>
		<G11Speed>50</G11Speed>
		<G11ExtraDistance>0</G11ExtraDistance>
		<G11ExtraLongDistance>0</G11ExtraLongDistance>
		<G10ZLift>0</G10ZLift>
	</movement>
	<shape>
		<grid color="#454545" spacing="10"/>
	<circle color="#dddddd" radius="100" x="0" y="0"/>
	</shape>
	<recover>
		<enabled>false</enabled>
		<replayExtruderSwitches>false</replayExtruderSwitches>
		<maxTimeForAutocontinue>300</maxTimeForAutocontinue>
		<reactivateBedOnConnect>true</reactivateBedOnConnect>
		<firmwarePowerlossSignal/>
		<procedure>G28 X0 Y0</procedure>
		<runOnConnect>G28 X0 Y0</runOnConnect>
		<extraZOnFirmwareDetect>0</extraZOnFirmwareDetect>
		<delayBeforeReconnect>30</delayBeforeReconnect>
	</recover>
	<extruders>
		<extruder changeFastDistance="20" changeSlowDistance="20" filamentDiameter="1.75" lastTemp="130" maxTemp="260" num="0" tempMaster="0">
			<alias/>
			<maxSpeed acceleration="5000" jerk="30" max="30"/>
			<extrude speed="2"/>
			<retract speed="30"/>
			<tempChange cooldownPerSecond="0.5" heatupPerSecond="2"/>
			<offsets x="0" y="0"/>
			<temperatures>
				<temperature value="245">ABS 245</temperature>
				<temperature value="210">PLA 210</temperature>
				<temperature value="195">PLA 195</temperature>
			</temperatures>
		</extruder>
	</extruders>
	<heatedBeds>
		<heatedBed lastTemp="0" maxTemp="110" num="0">
			<alias/>
			<tempChange cooldownPerSecond="0.1" heatupPerSecond="0.1"/>
			<temperatures/>
		</heatedBed>
	</heatedBeds>
	<heatedChambers/>
	<quickCommands/>
	<responseEvents/>
	<webcams/>
	<properties/>
<scripts/>
</printer>
The problem is he does not move when i send command s over the cmd:
22:31:58.468: start
22:31:58.481: N1 M110
22:31:58.481: N3 M115
22:31:58.481: N4 M220 S100
22:31:58.481: N5 M221 S100
22:31:58.481: N6 G92 E0
22:31:58.481: N7 G90
22:31:58.481: N8 M82
22:31:58.489: start
22:31:58.489: FIRMWARE_NAME:Repetier_0.92.6 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:3
22:31:58.489: PrinterMode:FFF
22:31:58.492: N1 G21
22:31:58.492: @getip
22:31:58.508: N1 M110
22:31:58.508: N3 M115
22:31:58.508: N4 M220 S100
22:31:58.508: N5 M221 S100
22:31:58.508: N6 G92 E0
22:31:58.510: FIRMWARE_NAME:Repetier_0.92.6 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:3
22:31:58.510: PrinterMode:FFF
22:31:58.519: N7 G90
22:31:58.519: N8 M82
22:31:58.519: N9 G21
22:31:58.519: @getip
22:31:58.540: M117 192.168.0.11:3344 (2)
22:31:58.552: M117 192.168.0.11 3344 (2)
22:32:13.468: @getip
22:32:13.500: M117 192.168.0.11:3344
22:32:13.518: M117 192.168.0.11 3344
22:32:27.256: N38 M114
And it just stays there for ages. I have a ESP3D for Marlin on the printer and i can controll it just fine.
Problem is the raptier.. The server reads all correctly, the temp and position.. but wont send any data.
  • Cant edit post anymore. I have an anycubic delta printer. When the server connects to the printer it displays the IP of the server correctly and all. but after that it just stops... i see the ack commands comming from the printer when i turn of the filters. it is just not sending any commands.
  • First I see you have selected Marlin as firmware, but log says it is running Repetier-Firmware. Communication differs a bit so better change to correct firmware in configuration.
    Log is from console I guess. You have disabled ack so I can not see firmware answers.
    I also see no move commands in the log so there will be no motion from this log. You can enable real logging to get full logs also over a longer period.
  • edited December 2019
    That is the same that bugged me.
    I dont have any repetier printer setup.
    Will provide a full log by 18:00 +1 gmt  not at home atm.
    Sorry for lack of ack.. i notice it now to. G28 does not move the printer, but i see the ack message. tht is what buggs me.
    Do you need something else that i can provide? :smile:
  • Ok repetier-firmware sends line number N with ok so easy to see if G28 was ack'ed. If so it is a firmware config or hardware problem.
    Also try moving after homing e.g.
    G1 X100 Y80 F6000
    M114
    and see what it returns as coordinates with M114. If it is 100/80 firmware at least thinks it has moved.
