Windows 10 pro latest Reptier server version cant send commands to the server.
I have this printer:
<?xml version="1.0" encoding="UTF-8"?> <printer> <general> <name>test</name> <slug>test</slug> <model/> <firmwareName>Marlin</firmwareName> <printerVariant>delta</printerVariant> <active>true</active> <numFans>1</numFans> <tempUpdateEvery>1</tempUpdateEvery> <pauseHandling>0</pauseHandling> <pauseSeconds>120</pauseSeconds> <doorHandling>1</doorHandling> <sdcard>false</sdcard> <softwarePower>false</softwarePower> <defaultVolumetric>false</defaultVolumetric> <logHistory>true</logHistory> <useOwnModelRepository>true</useOwnModelRepository> <useModelFromSlug/> </general> <connection> <connectionMethod>2</connectionMethod> <pipe> <file/> </pipe> <ip> <port>8888</port> <address>192.168.0.10</address> </ip> <serial> <baudrate>0</baudrate> <rts>0</rts> <dtr>0</dtr> <device>VirtualDelta</device> <pingPong>false</pingPong> <visibleWithoutRunning>false</visibleWithoutRunning> <malyanHack>false</malyanHack> <inputBufferSize>127</inputBufferSize> <communicationTimeout>30</communicationTimeout> </serial> <lcdTimeMode>4</lcdTimeMode> <resetScript/> </connection> <movement> <xMin>-100</xMin> <xMax>100</xMax> <xHome>0</xHome> <yMin>-100</yMin> <yMax>100</yMax> <yHome>0</yHome> <zMin>0</zMin> <zMax>100</zMax> <zHome>0</zHome> <xyJerk>20</xyJerk> <zJerk>0.30000000000000004</zJerk> <timeMultiplier>1</timeMultiplier> <movebuffer>127</movebuffer> <xySpeed max="200">100</xySpeed> <zSpeed max="2">2</zSpeed> <defaultAcceleration>10000</defaultAcceleration> <defaultTravelAcceleration>10000</defaultTravelAcceleration> <defaultRetractAcceleration>4000</defaultRetractAcceleration> <xyPrintAcceleration>1500</xyPrintAcceleration> <xyTravelAcceleration>2500</xyTravelAcceleration> <zPrintAcceleration>100</zPrintAcceleration> <zTravelAcceleration>100</zTravelAcceleration> <endstops all="true" x="true" y="true" z="true"/> <invert x="false" y="false" z="false"/> <G10Speed>50</G10Speed> <G10Distance>3</G10Distance> <G10LongDistance>50</G10LongDistance> <G11Speed>50</G11Speed> <G11ExtraDistance>0</G11ExtraDistance> <G11ExtraLongDistance>0</G11ExtraLongDistance> <G10ZLift>0</G10ZLift> </movement> <shape> <grid color="#454545" spacing="10"/> <circle color="#dddddd" radius="100" x="0" y="0"/> </shape> <recover> <enabled>false</enabled> <replayExtruderSwitches>false</replayExtruderSwitches> <maxTimeForAutocontinue>300</maxTimeForAutocontinue> <reactivateBedOnConnect>true</reactivateBedOnConnect> <firmwarePowerlossSignal/> <procedure>G28 X0 Y0</procedure> <runOnConnect>G28 X0 Y0</runOnConnect> <extraZOnFirmwareDetect>0</extraZOnFirmwareDetect> <delayBeforeReconnect>30</delayBeforeReconnect> </recover> <extruders> <extruder changeFastDistance="20" changeSlowDistance="20" filamentDiameter="1.75" lastTemp="130" maxTemp="260" num="0" tempMaster="0"> <alias/> <maxSpeed acceleration="5000" jerk="30" max="30"/> <extrude speed="2"/> <retract speed="30"/> <tempChange cooldownPerSecond="0.5" heatupPerSecond="2"/> <offsets x="0" y="0"/> <temperatures> <temperature value="245">ABS 245</temperature> <temperature value="210">PLA 210</temperature> <temperature value="195">PLA 195</temperature> </temperatures> </extruder> </extruders> <heatedBeds> <heatedBed lastTemp="0" maxTemp="110" num="0"> <alias/> <tempChange cooldownPerSecond="0.1" heatupPerSecond="0.1"/> <temperatures/> </heatedBed> </heatedBeds> <heatedChambers/> <quickCommands/> <responseEvents/> <webcams/> <properties/> <scripts/> </printer> The problem is he does not move when i send command s over the cmd: 22:31:58.468: start 22:31:58.481: N1 M110 22:31:58.481: N3 M115 22:31:58.481: N4 M220 S100 22:31:58.481: N5 M221 S100 22:31:58.481: N6 G92 E0 22:31:58.481: N7 G90 22:31:58.481: N8 M82 22:31:58.489: start 22:31:58.489: FIRMWARE_NAME:Repetier_0.92.6 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:3 22:31:58.489: PrinterMode:FFF 22:31:58.492: N1 G21 22:31:58.492: @getip 22:31:58.508: N1 M110 22:31:58.508: N3 M115 22:31:58.508: N4 M220 S100 22:31:58.508: N5 M221 S100 22:31:58.508: N6 G92 E0 22:31:58.510: FIRMWARE_NAME:Repetier_0.92.6 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Delta EXTRUDER_COUNT:2 REPETIER_PROTOCOL:3 22:31:58.510: PrinterMode:FFF 22:31:58.519: N7 G90 22:31:58.519: N8 M82 22:31:58.519: N9 G21 22:31:58.519: @getip 22:31:58.540: M117 192.168.0.11:3344 (2) 22:31:58.552: M117 192.168.0.11 3344 (2) 22:32:13.468: @getip 22:32:13.500: M117 192.168.0.11:3344 22:32:13.518: M117 192.168.0.11 3344 22:32:27.256: N38 M114 And it just stays there for ages. I have a ESP3D for Marlin on the printer and i can controll it just fine. Problem is the raptier.. The server reads all correctly, the temp and position.. but wont send any data.
Log is from console I guess. You have disabled ack so I can not see firmware answers.
I also see no move commands in the log so there will be no motion from this log. You can enable real logging to get full logs also over a longer period.
I dont have any repetier printer setup.
Will provide a full log by 18:00 +1 gmt not at home atm.
Sorry for lack of ack.. i notice it now to. G28 does not move the printer, but i see the ack message. tht is what buggs me.
Do you need something else that i can provide?
Also try moving after homing e.g.
G1 X100 Y80 F6000
M114
and see what it returns as coordinates with M114. If it is 100/80 firmware at least thinks it has moved.
