Strange slicings with sli3r. Additional sliced things not existing in the model
Hi! I think it was since I upgraded to repetier-host c2.0.5. I slices with slic3r, and you can see the model and the slicing... Any of you know why that additional strange perimeters?
It is going to make it install an earlier version. In this model is not important, but it makes it in other models in more relevant parts...
Thanks a lot.
Best regards.
Thanks a lot.
Best regards.
In fact, I re-installed 2.0.1 version, and now the same model with the same profile does not show that...
I would like to know the reason to be able to upgrade, so any suggestions will be welcome!
Thanks.
Regards.
Thanks for your support!
Does this happen only to me?
Thanks for any suggestion.
Best regards.
The only additional thing I have is skirt, but I removed it and skirt dissapeared, but not the issue.
Brim is at "0", not activated, Support not activated. Shield and prime tower are options that I do not find in any setup tab. So I am lost...
Do you get that with EVERY model or only one special. Also does it happen if you only have one object on bed.
You can see other example bellow (model and slicing): Skirt, brim, support, all of them at "0" or unselected...
I think I have to move to other printing software, as I do not know what is causing this...
Thanks!
set this to 0 and you should be good to go.
Thanks a lot Martin. Really appreciated your time and advice!
