Nozzle size increase not showing properly
I just changed from a .4 nozzle to a .6 nozzle. I made the changes to reflect this but the print preview keeps showing gaps in the walls and solid infill. I use Cura but I've also tried Slic3r and they both show this. It's like it's not seeing the nozzle diameter correctly. I've tried everything I can think of but I can't get it to show bigger nozzle sizes properly.
Any help would be greatly appreciated.
Here is what the .6 nozzle looks like.
This is what the .4 looks like
I changed it from layer height to filament and had to bump the width over thickness up from the 1.6 to 2.4.
Thank you for you help.
In fact, when I slice and print this at 0.4mm nozzle, the gap is closed up and the part is useless.
In order to get the filament visualisation to show this gap closure I must set width over thickness to be 9.
OK - so now it looks like the actual print, but a more fundamental problem is - how do I configure the slice to preserve the gap? I have changed trhe gap width in the part design to 0.7 but the printed part still has the gap closed up. How do I preserve this gap?
