Ramps 1.4 does not read heated table
I'm an annoying problem, my ramps just stopped reading the temperature of the table, the hotend is ok. But the table will not even pray with mad !!!
Already tested the thermistor in other ramps! and it is ok
Already redid the cable same stubbornness and nothing to read the temperature.
What I am trying to do is change the current T1 to T2 since I have only one hotend, I'm using the ramps 1.4 and the Repetier Host 0.92.
Which file should I change? I think it's in pins.h file but do not know how to do.
  • You only need to change configuration.h. Set
    #define HEATED_BED_SENSOR_PIN TEMP_2_PIN
    to use the other thermistor input from extruder 2.
