Repetier Host manual control for extruder issue
Currently using Host 1.5.3 and firmware 0.92.3.
Just noticed today that the Host manual control for extruder is doing funny. Obviously after the default minimum temp 150C reach.
The problem is I could only rotate the extrude motor when I click 'retract' and then 'extrude' and then 'retract' and so on (back and forward every other direction). So basically if I click 'extrude' and then 'extrude' again, the second click is not doing anything. The same issue on the 'retract' rotation.
Also noticed that no matter which button (1, 10, 50 or 100) I clicked, it is always spin for the same number of rotation.
Interestingly I could both extrude and retract normally through the LCD control. I could spin the extruder motor as far as I want both extrude and retract direction.
fyi, part of the debugging I tried reinstall the Host 1.5.0, but not make any different.
I also tried reupload the a-week-older-firmware that the extruder manual control in the Host 1.5.0 was working normal a week ago.
So something happen not normal inside the Host as much as I understand. Any idea that might cause this?
The commands looks correct, here I copy paste when I click the manual control for 'slow extrude 10'.
