firmware configuration disabled
I have a Monoprice Maker Select (Wanhao I3), and M115 returns this:
FIRMWARE_NAME:Repetier_0.91 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:2
The printer is connected with USB, and as far as I can tell everything looks fine, except that the menu option "firmware EEPROM config Alt-E" is greyed out.
Am using Repetier-Host under Windows, and I believe it is the latest version.
What do I need to do to be able to edit the EEPROM from the computer?
