offset
i have installed a dual extruder and everything works fine but now i come to the point where i need to set the offset. if i put the offset in slic3r it works fine but there i have the problem that it doesnt place objects in the air. whit teh cura engine it does work but i cant change the offset in cura and if i put the offset in the eeprom it doesnt change annything. so what do i hacve to do?
Regarding probe offset if it is wrong it will still probe but assign result to wrong position, that's all and will still work. Before starting probing just go to bed center and start from there then activation is possible. You still of course need coordinates reachable with activated offset.
