Big Problems with Correction Map G33 on Delta Printer with 100mm Radius Bed
Hi all :)
First of all sorry for my very bad English ;)
I had a Delta Printer with a 100 radius Bed. G32 does not work very well for me because the bed is not 100% flat.
So i wanted to switch to g33 (DISTORTION_CORRECTION)
BUT !
If i start G33 the Print Head always run out of Bed on Top Left Corner :( and i had to Emergency Stop them to get no Damage.
the Parameters in Firmware are
#define DISTORTION_CORRECTION_POINTS 8
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_CORRECTION_R 95
#define DISTORTION_XMIN -60
#define DISTORTION_YMIN -60
#define DISTORTION_XMAX 60
#define DISTORTION_YMAX 60
Firmware Version are lastest Stable 1.0............
I Dont know why. plz help me ! :)
Board is Arduino Due 32 Bit
  • falls mir jemand antworten möchte auch gerne in deutsch :)
  • nobody has an idea?
  • For deltas
    #define DISTORTION_EXTRAPOLATE_CORNERS 1
    is always a good thing to increase the testable area. Always think that extruder with applied z offset needs to reach the positions. In this case a lower DISTORTION_CORRECTION_POINTS is normally helpful. 5 is a good value.
    Reduce DISTORTION_CORRECTION_R if it still does not fit!
    Also always run G33 AFTER G32 and not alone. You still want to correct bed tilt in addition to bumps.
  • edited May 2019
    ist there any way to got a list of the coordinates without driving the effektor ?
    thanks for your answer i will test that
    now i use
    #define DISTORTION_CORRECTION_POINTS 5
    #define DISTORTION_CORRECTION_R 90
  • it works :)
    #define DISTORTION_CORRECTION_R 80 works fine !!!!
    thx !
