Big Problems with Correction Map G33 on Delta Printer with 100mm Radius Bed
Hi all
First of all sorry for my very bad English
I had a Delta Printer with a 100 radius Bed. G32 does not work very well for me because the bed is not 100% flat.
So i wanted to switch to g33 (DISTORTION_CORRECTION)
BUT !
If i start G33 the Print Head always run out of Bed on Top Left Corner and i had to Emergency Stop them to get no Damage.
the Parameters in Firmware are
BUT !
#define DISTORTION_CORRECTION_POINTS 8
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_CORRECTION_R 95
#define DISTORTION_XMIN -60
#define DISTORTION_YMIN -60
#define DISTORTION_XMAX 60
#define DISTORTION_YMAX 60
Firmware Version are lastest Stable 1.0............
I Dont know why. plz help me !
Board is Arduino Due 32 Bit
#define DISTORTION_EXTRAPOLATE_CORNERS 1
is always a good thing to increase the testable area. Always think that extruder with applied z offset needs to reach the positions. In this case a lower DISTORTION_CORRECTION_POINTS is normally helpful. 5 is a good value.
Reduce DISTORTION_CORRECTION_R if it still does not fit!
Also always run G33 AFTER G32 and not alone. You still want to correct bed tilt in addition to bumps.
thanks for your answer i will test that
now i use
#define DISTORTION_CORRECTION_R 80 works fine !!!!
thx !
