Please help with Z-Probing
This is my printer, it's a DIY Felix printer design, Please refer to the attached images.
This is my configuration.h
with this config, when I send G30 am always having the error of:
My print bed couldn't reach the 0 position because of its limited size so I need to back on home at 35mm for X and 20mm for Y.
Why it's 35mm for X is because I need to position my inductive sensor inside the alum bed.
Thanks in advance for the help.
Images link: https://ibb.co/SPDdS4r
#define ENDSTOP_X_BACK_ON_HOME 35
#define ENDSTOP_Y_BACK_ON_HOME 20
#define ENDSTOP_Z_BACK_ON_HOME 5
#define X_MAX_LENGTH 158
#define Y_MAX_LENGTH 148
#define Z_MAX_LENGTH 185
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 35
#define PARK_POSITION_Y 20
#define Z_PROBE_Z_OFFSET 2.7
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_BED_DISTANCE 5
#define Z_PROBE_PULLUP 1
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 32
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 5
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 5
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 1.3
#define Z_PROBE_DELAY 0
#define Z_PROBE_REQUIRES_HEATING 1
#define Z_PROBE_MIN_TEMPERATURE 0
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 -37//-20 // 35
#define Z_PROBE_Y1 20//-40 // 20
#define Z_PROBE_X2 158//70
#define Z_PROBE_Y2 5//-20
#define Z_PROBE_X3 -37//0
#define Z_PROBE_Y3 143//80
#define BED_LEVELING_METHOD 1
#define BED_LEVELING_GRID_SIZE 3
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 200
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
Error:Activating z-probe would lead to forbidden xy position: -33.000000, 0.00
#define Z_PROBE_X_OFFSET -32
Also i think your X1 and X3 probing locations need to be positive.
min/max values changed to put probe inside bed edge
in case of probe Z home I have put:
#define HOMING_ORDER HOME_ORDER_XYTZ
You could try
I've tried your suggestion but when I home Z, I got the same error right away. Earlier values are better I think this time. What could possibly wrong with my printer? Am using 1.0.3 FW version.
