Extruder/bed not heating up with new install
I recently had to replace my Ramps 1.4. I had Repetier .92 installed on my arduino mega 2560, i tested all of the functions on the ardiuno/ramps with success (steppers move, extruder heats up, temperature readings are correct and so on). After installing a Heated bed and Inductive sensor I modified the firmware config.h file to support the bed and sensor, re-flashed the arduino and now the extruder as well as the bed no longer get hot (Thermester readings are still correct)
