Z-Probing, Correction matrix and Z-Home
I am facing an issue with 1.04 or so.
"ALWAYS_CHECK_ENDSTOPS" seems to not working anymore for movements.
In fact it is still check at movements.
Just home the Printer and try to go below 0.0mm in Z in the "Move" Panel. Does not work anymore.
With "Slow" you get -0.01mm but thats it.
The effect in Print: If you need to go below 0.0mm (i.e. -0.05mm) because of Leveling/Correction matrix, this move is not executed. No Error, no nothing, Z still at 0.0mm, just not moved. But going up is working. So you constantly going away from bed, going out of sync. In the test I'm printing you end up with arround 0.6mm Z away from bed in the first layer.
You don't even home the printer. Just go away from bed, switch off/on, try to move below 0.0mm. Does not work.
snipped from my configuration.h:
Oh, I'm using Visual Code to compile firmware. Good move, I really like it.
These tests are executed on global official coordinates, so they should still do internal bump correction even if it goes below bed. Probing also is not affected by the position test so will probe below z=0. Yes you can not move below 0 without homing which restores right bottom. Same for X- and Y- direction. Actually I would even recommend disallowing motions before homing at all. There are now switches to prevent that.
Can you explain the leveling error a bit more. That is the only thing that does not seem to work as expected. During leveling/bump mapping you should start from a level well above z=0 after homing. z probe goes always back to start height. Why should it always go higher. What is your exact test sequence here.
I will disable correction matrix first, than ABL and let you know the results.
As of now I am not really sure what happens. All I can see is the behaviour described in first post.
sorry for late reply.
I doubled check the next day and it is working as expected. This is really crazy. I do not have an idea what happened before...
Anyway, I keep an eye on this.
