End stop state unaffected in LCD
I have a Radds-board with Smart Controller from RepRap Discount, latest firmware (0.92.3).
I'm having some issues with my end stops, the thing is, triggering the switch manual doesn't change the state in the "Position" sub menu. Only when the motors are operated, and that causes the switch to be triggered, does it change from off to on in the LCD sub menu.
Sending g-code M119, to check end stops, from the interface-host works without motors are being operated, and end stops being triggered manually. Homing functions also works, so it's not a huge thing.
I noticed because I have another printer with same firmware (0.92.3) on a RAMPS-board with full graphics controller, and the end stops changes state immediately in LCD menu, when triggered manual.
Best regards
Best regards
I was wondering if these changes are published somewhere?
Github doesn't appear to be up to date?
https://github.com/repetier/Repetier-Firmware/blob/master/changelog.txt
Just a heads-up, as long as I can get my answer here it's cool.
