Azteeg X3 Pro - 7th and 8th driver problems
I'm having issues using the 7th (or 8th) driver my Azteeg X3 pro board. Everything works great on the first six drivers. I recently added a second extruder that I can't get to function correctly. I think it is a firmware issue that I could use help identifying.
I've tested the motors, drivers, and wiring - all of which work independently by when i flashed a test sketch. I was also able to get the new stepper driver to run when using Marlin - but I don't like marlin and would rather use repetier.
I've been using repetier host to send gcode. Any thoughs?
It looks like you posted a copy of your config on another thread. Thanks for doing that. It is a nice sanity check. Cheers.
Well I'm an idiot...
EEPROM was set wrong
Thanks for the help.
