Ditto Mode Identically or Mirror
Hey Devs,
after running the configuration tool and looking at the firmware, would it be correct to say that if I have to switch between ditto mode identical and ditto mode mirror, i would have to reconfigure and upload the firmware each time.
thanks.
thanks.
in config tool 1.0.3, there is Dual X Axis and also M280 command
Guess you meant mirror in the sense of copy and not as I defined it.
would it be correct to say that in the configuration tool->Tools->Extruder
does not mean i can create a mirrored print?
