CNC settings
Hi, I am setting up a CNC on the style of a 3D printer, And I see that Pepetier has settings for this.
Is there any other settings to make other that enabling it..
Can someone enlighten me on this, do you use it just like the printer.
Thanks.
Thanks.
I will be using a MKS GEN 1.4 board, where would it be best to connect the spindle.
Extruder outputs can have 1-2A at main power voltage (12 or 24V). If spindle requires 220V you can not control it directly. You may make a SSR for it driven by extruder output or like me just keep it powered all the time.
The spindle I have has a speed controller board, So I will be able to power it directly from the PS.
The base plate is aluminum 380 X 280 X 5 mm, you would then have the size and weight of the material.
I am planing for a belt drive.
