LCD setup
Hi, I have Repetier uploaded and printing via my laptop, but would like to connect and LCD screen.
I have the reprap full graphic screen.
I am a little weary about it, because I could never get Marlin to accept the U8glib file, how would this effect Repetier. Thanks
I have the printer up and running now, and must say the prints are far better than I ever got via Marlin.
or if you used config tool just select the display type and get the new configuration.h for compilation. After recompile it should show up if you used a board with support for that board. But it is the most widely used display so chances are good.
I do not wish to go through the configuration again now that it is working, took me long enough in the first place.
Got that, one problem left, the SD card how can I set that, it;s not reading the card.
I don;t want to go to go to online config.
sorry for being dumb
It tells me when the card is inserted and when it is removed, but it is not reading the card, maybe the board is faulty I don't know, that is why I am here
The card itself seems to be fine I can read ir else where
