New Mini-Rambo: No start signal detected - forcing start
Long story short: I have a Prusa i3 I purchased from Folgertech. I moved and had to change out the Arduino. I decided to get the Mini-Rambo (pre-flashed) from vicious1.com.
Hooked it up. Now I have a "No start signal detected- forcing start" message from Repetier-Host.
Mini-Rambo is blinking yellow/amber light.
Thank you for the any help I can get from the Genius folks in this forum.
Will I have to flash the board with firmware configured with baud rate 115200?
After I changed the Baud rate the board still doesn't connect.
